Pot Value/Type for Expression Pedal?
Started by indytone, February 13, 2007, 09:43:50 AM
indytone
I have a 4ms stereo tremulus panneur with the speed expression input on the side and a Moog expression pedal. I'm pretty certain that if I can switch out the pot in the expression pedal it will fix my current issue.
The issue is that the expression pedal doesn't start to have an effect on the speed of my tremulus panneur (or my vox repeat percussion clone [modded w/ speed expression input as well]) until I have it almost totally depressed, and at that time it's as if it goes from 0-100 immediately. I have adjusted the height of the 'gear' that controlls the turning of the pot, but that isn't helping.
I think the solution is the replace the pot in the expression pedal with one of a different value that will allow for a more smooth and constant "expression." I've googled and seen posts also suggesting this fix, but none specify what kind or value of pot to replace it with.
Anyone here have experience with this sort of thing?
Processaurus
Easiest would be to. ask 4ms, they probably had a certain brand/type pedal in mind when they developed it.
