A Few Quick Questions
Started by kurtlives, December 25, 2007, 11:51:16 PM
kurtlives
Ya I figured the transistor question shortly after opening my mouth. I bought them from futurlec and they have data sheets for all their transistors...so yeah.
Damn so I need a 1N100. Do you think a 1N34a or 1N270 would be a good substitute?
My DIY site:
www.pdfelectronics.com
kurtlives
Can anyone confirm if a 1N34a will work? I pretty sure it will but I want to be sure.
My DIY site:
tcobretti
kurtlives
Thanks so much for all your help tcobretti, you have been so helpful.
My DIY site:
tcobretti
kurtlives
So how does this wire work? http://www.smallbearelec.com/Detail.bok?no=86
Is there two leads in the insulations? Does one go to ground and the other to the joint?
My DIY site:
tcobretti
Yes you can wire it with the shielding to ground and the core to whatever signal you want to pass.  Most people just use normal wire.  Shielded wire is useful, however, if the pedal is oscillating badly.
Basically, I wouldn't use that type of wire for most applications.  I just use any small wire that I can find.
kurtlives
Well I am building a high gain beast so I figire I better use it.
My DIY site:
