Newb- Help putting 2 pedals into one enclosure.
Started by msurdin, February 15, 2007, 05:37:04 PM
msurdin
Hi,
I have been confused from when some people have told me (other forums) on how to rehouse 2 different pedals into 1 enclosure.
Can someone explain to me if I remove the in jack and there is a battery attached to that where do I connect the wire going to the clip that was on the jack(I  just want 9v adaptor power). Is there any diagrams of doing this any wear?
Thanks for your patience and help!
jimbob
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
The black wire from the jack to the battery is to switch off the battery when the guitar lead is unplugged.
If you're only going to be using a DC adaptor just attach it to ground somewhere. Or you could probably completely remove the battery clip.
