diode remplacement
Started by Gila_Crisis, February 21, 2007, 07:09:42 AM
Gila_Crisis
hi, i wanna build the dirty bird, but i can't find the NTE112.
want other diodes can i use in place of this???
Paul Perry (Frostwave)
I think that's a schottky diode.
So I'd use a BAT84 (because I have several lifetimes supplies of them). But any schottky would do, I expect.
Gila_Crisis
ok, and what exactely a schottky diode??
A Schottky diode is a diode formed by depositing a metal layer on a doped silicon substrate so it forms what amounts to a "half diode". It still acts like a diode, but has half the forward drop and is very fast in turning on and off.
Schottky diodes would be great for everything except that the "half diode" construction makes fabrication a bit more difficult and the reverse voltage is limited. The first Schottky diodes were only a few volts for reverse blocking. Improved design gives silicon Schotty diodes with voltages up to maybe 50. I've even seen adverts for 100V Schottkys, but that was on a silicon carbide semiconductor.
The old point contact diodes, cat whisker on galena crystal and the ilk were in effect Schottky diodes.
Gila_Crisis
i founded a 1n5817, can i use that?
Yeah, the 1N5817 is a Schottky. It's a low voltage one; in a 9v effect should be fine.
zjokka
Quote from: R.G. on February 21, 2007, 11:02:10 AM
The guy at the store said he only stocked 1N5819 because same as 1N5817 an 18 just higher amperage. Didn't check the sheet though
That wouldn't be a problem in stompbox applications would it?
thanks
zj
No problem at all.
I must say zjoka, I'm impressed that there is an electronics store anywhere in the world where the guy behind the counter knows something!
km-r
wow, that was quite some guy for an electronic store counter...
thats smoove!
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
