Rebote 2.5 not delaying
Started by WelshWonder, March 15, 2007, 12:51:32 PM
WelshWonder
I just completed the Rebote 2.5 delay using all recommended values execpt the following
0.87uF - 0.1uF
0.027uF - 0.022uF
51pF - 47pF
5pF - 4.7pF
The signal goes through okay but there is no effect. Any suggestions on where to start to debug?
WelshWonder
Ah just ignore it, solved the problem. The battery was not at full capacity. Tried with 9V adapter, now working!
WelshWonder
Just played with it a bit, what an amazing pedal! Love the delay, I'm 90% sure I'm going to sell my Deluxe Memory Man now.
blanik
check out you battery connection, when the battery gets too low the Rebote will oscillate like crazy not just send unaffected signal through...
and a properly set up Rebote without LEDs or with low current draw LEDs will have a battery life of many months of regular use!!! good reason by itself to sell the DMM (plus all the real estate you'll save on a board or in a gig bag if you box your Rebote in a small or medium Hammond box)
R.
