Fuzz Face Debug
Started by goofball_11, March 21, 2007, 03:20:26 PM
goofball_11
Hi im building a fuzz face PNP according to GGG's layout, i followed it exactly and it worked for a few days and now when the effect is engaged no sound is produced.
Q1 E=6.1        Q2 E=6.4    C1=0         R2=3.4
     B=1.4             B=3.4    C2= 6.1     R3=6.1
     C=3.4             C=6.4   C3=6.1       R4=8.8
and the ground is 6.1V
can somebody please help me figure this one out
goofball_11
o and i used the transistors from smallbear
goofball_11
Can you give us a link to exactly the schematic you used?
The voltages you list don't seem to match up. For instance, ground is always 0V by definition. So ground can't be 6.1V.
Did you try to do the negative ground trick on this PNP circuit?
goofball_11
what would make my ground voltage = 6.1V? :icon_confused:
joegagan
your ground is touching something that has voltage.
check all your connections and especially for solder bridges where they shouldn't be.
goofball_11
#7
Alright, ive completely unwired the thing except for the - battery and im gettin the same voltage through Q1E as the ground and they are attached on the layout. A jumper means just a connection right? because for the jumper i just took the extra part of leg from a transistor. http://www.generalguitargadgets.com/diagrams/fuzzface_lo_pp.gif
Also im just curious if the positve side of C1 is supposed to be 0
and one more thing, how would i go about removing the dc jack from the circuit
goofball_11
#8
the voltage of the ground is now 1.2V
goofball_11
seriouslyi cant see any solder bridges whatsoever, is it possible to be anything else
goofball_11
