Orpheum Fuzz help
Started by black mariah, March 20, 2007, 04:28:30 AM
black mariah
I built the Orpheum fuzz, but it doesn't sound right... err... wrong... whichever. :icon_lol:
The initial hit is very compressed, and not in a good way. The volume drops and blooms when you hold the chord. Cool sounding, but not what I'm looking for. I want something closer to the clips in Dragonfly's album, like this: http://aronnelson.com/gallery/albums/album109/orphclone1.mp3
I used 2N2222 transistors since they were handy.
Q1
C = 6.7
B = .56
E = .1mV
Q2
C = 3.3
B = .54
E = .1mV
Battery was fresh from the packaged, measured at 9.75V. Makes me wanna watch crappy commercials for late-80's RC cars. How 'bout you? The only deviation from the layout is that I used a .15n cap for C2 instead of a .1, which I didn't have. My pickups are both single coils, so that should be an issue like I know humbuckers can sometimes be.
MartyMart
May be some help in here :
http://www.diystompboxes.com/smfforum/index.php?topic=52314.20
Seems like the bias is very shakey on this and perhaps the trannies have a big
effect too.
black mariah
I just noticed that my Q2 C voltage is nearly four times that of the others that have been posted. Methinks a trim pot is in order.
black mariah
Correction. I did something wrong. Don't ask what. It's dumb.
The Q2 voltage is more like .85, not 3.3. I'm dumb. Derp.
MartyMart
No worries, we all do it, my BEST one is wondering why there's no output
and then looking down at an empty "IC socket" !!!!    :icon_mrgreen:
smnm
Quote from: black mariah on March 20, 2007, 04:28:30 AM
I want something closer to the clips in Dragonfly's album...
I built this a few weeks ago and was disappointed with the sound at first - like MartyMart says, the transistors have a big effect.
To my ears 2N2222s can be very shrill, but it's down to taste. I couldn't find the 2n903s that Dragonfly used, and tried a few diff combinations of what I had around, ending up with in a couple of BC547s - they sounded closer to the clip, but still not as good.
I'm going to do a methodical audition of various transistors sometime when I've got nothing better to do. I find my ears get tired easily and what sounds great one day sounds bad the next. I'm thinking BC141s might be good, to retain a bit of bottom end...
I tried a lot of transistors in my Fuzzrite before I liked it, too.
black mariah
Did some experimenting. I removed R3 completely so power is only going through R5. That helped quite a bit. I also changed the tone pot to 250k for no reason in particular. Didn't change much. Maybe a higher value would work better.
The best mod was to put my LPB in front of it. I swear that thing is magic. It's still too farty and not squishy enough (could I BE more vague?) but it's workable.
I'm gonna just have to break down and build a Superfuzz and do it RIGHT.
doug deeper
Quote from: MartyMart on March 20, 2007, 07:43:40 AM
i do this once a week!
black mariah
Quote from: doug deeper on March 20, 2007, 02:11:12 PM
EVERY build I do has at least one major "How the hell did I miss that?" moment. For the Orpheum I got it all wired up, plugged it in... no sound. Dig around, reflow joints... then notice the battery ground came loose. :icon_rolleyes:
MartyMart
I did have "more" problems a year or two ago, until learning a very obvious lesson, probably
inspired by RG's advice, which leads to this :
First choose a "known good" project - be it schematic and/or layout, some thing that's been built
many dozens of times, ROG/Tonepad/GGG are good places to start.
Follow it through slowly and carefully, check resistor and cap values - measure if you're unsure and
look up/download data sheets for any fets/BJT's or IC's that you'll be using.
Check the pot and output wiring, are pots marked "CW" or "CCW"  ?
Use sockets for trannies and IC's when possible.
Once completed, go over the circuit with your schematic handy and "tick off" every connection with
a highlighter pen.
If built correctly "THE CIRCUIT WILL WORK" otherwise you have a mistake/error and just need to
find it, sometimes it's a silly one and sometimes a bugger to find like a cold solder etc.
I now very rarely have a "non-worker" and have only been beaten by two circuits, which I was
laying out myself, one was a P-90  !
MM.
