ROG phozer and other wobbly type effects
Started by burnt fingers, May 17, 2006, 03:36:58 PM
burnt fingers
Greetings,
After finishing my Bobtavia yesterday I need a new project.  I though I'd try the ROG phozer or tim escobedo's wobbeltron or photon filter.  I do not have any Darlington transistors so my question is what if any problems would there be in using say a 2n3904,5088 etc. in the phozer.
Also, if anyone has built any of these projects, were you pleased with the results.  I heard the sound samples for the phozer but have not heard any for the photon filter or woblletron.
Scott
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
nelson
I havent built the phozer etc. But you can make a darlington transistor out of two of your normal NPN.
Here is a diagram.
from wikipedia.
My project site
Winner of Mar 2009 FX-X
burnt fingers
Thanks nelson.  I might give that a try.
I'm still  interested in hearing about the wobbletron or the photon filter. Any good/bad/indiffernt comments or sound clips.
Thanks ;D
My Music
Noplasticrobots
I just built the Wobbletron last night (the first wobbly effect I've ever gotten to work!). It sounds cool, but is noisy and choppy. You need to add a decoupling cap between the emitter of the MPSA18 and the JFET, then reground both transistors with a 10k resistor.
I love the smell of solder in the morning.
burnt fingers
wow I forgot about this post.  My wobbletron was marginally successful.  It distorted a lot with humbuckers and I had to try a few j201's before I got a decent amount of wobble.  I still have most of it on a board so I suppose I could try the suggestions all though I pretty much wrote this one off.
Scott
My Music
