Build Report: The Beginner Project (NPN Boost)
Started by newbie builder, March 28, 2007, 05:52:51 PM
newbie builder
It appears to me that, at least once a week, somebody posts a thread about "what is your favorite boost" and myriad replies follow. One that I recently noticed isn't mentioned too often is the Boost that is depicted in the "Beginner forum," but I'm starting to think it should be mentioned I just finished building it after playing around with it on the breadboard and it's really a great little boost. It isn't as woofy and has more clarity than the LPB, it has a bit less high end for those who believe that the AMZ Mosfet boost is a bit on the sparkly side, and is a very easy build. I played around with it and decided my favorite transistor in there was a 2n5089 (2n3904 was the second choice of the ones I tried), and also played around with clipping diodes after the 10uf cap. First I tried some Schottky diodes (symmetrical clipping) but they clamped down the signal too much and there wasn't enough boost using those. LEDs had too high of a threshold and didn't clip unless the boost was turned up VERY high. I went with some 1n4148s as a nice in between mix of gain and boost and wired those up on a toggle so I can have semi-dirty or mostly clean boost. I think some, though definitely not all, people (myself included) have looked over the project simply because it is called a "Beginner project," but it is really a nice little boost.
I'll try to add some pics later today/tomorrow when I have a chance to box it up, but I have a feeling this one is going to look a bit messy...I hadn't perfed anything in a while before this and forgot how much more time it takes to make a project on perf look nice vs. the stripboard I'd been using recently.
  +1.
  It seems the word has a dissuading effect to beginners eyeing the NPNBoost, it is less 'beginner-ey' using higher parts count and a bit more wiring than simpler 1 transistor gain stages. It isn't 'less sophistocated' by any means...it seems attempting to explain around 'beginner' to a beginner causes them to sometimes believe there is something about it being 'lesser' than an 'intermediate' or 'advanced' build [1Q boosts are all ~simple].
  It was one of the first builds for me, cause it had two pots and all, still one transistor..but I didn't build so good back then, just threw stuff together on a bookcover, in a tin box, w/funky Sw..it fell apart...sounded great though, I bummed.
  I've recently built mostly Gus' stuff, he helped me out diggin into the power mosfets, NPN boost, I should probably try that again.
cab42
Quote from: newbie builder on March 28, 2007, 05:52:51 PM
I have had the same thoughts as well and I have mentioned this boost in a couple of threads.
I use mine all the time. I have mine set up with two transistors so that I can switch between a 2N2222 and a OC140 germanium.
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
GibsonGM
+1
I use the Beginner Boost all the time when I play out (and when I don't, lol).  2N3904, only cuz it was laying around.   Had a few small issues with motorboating, but I'd used a larger cap between wiper & ground on my pot -- might have been the culprit.  It was ok after I changed it out.   You can go anywhere with this thing, perfect building block for experimenting.   8)
MikeH
Guilty.   :P   Now I have to go build this.
Gus
I made the npn as a kind of challege to myself.  Min amount of parts and something different than what is out there.
Bootstrapping is old: However I have not seen it in an boost effect.
I "designed" it so a lot of different transistors could be "dropped in" without worrying about bias.  At the time I built it most if not all of the parts could be bought at Radio Shack.
Another circuit people seem to like that tried it is
http://www.diystompboxes.com/pedals/gusOverdrive.gif
Another min boost EQ again different transistors can be "drop in"
It is good to read people like it and have some fun with it.
Aharon
Quote from: cab42 on March 29, 2007, 02:57:53 AM
Regards
Carsten
Yap,I ended up with a metal can 2N2222 as my favourite.
Aharon
markm
I have a nice layout for this little circuit, I'd post it but, the Gallery is still down.  :icon_frown:
