Negative voltage from charge pump
Started by scotsman, April 06, 2007, 01:24:25 PM
scotsman
I'm looking to add a charge pump to my Maxon Analog Delay - which uses -12v so I can use my normal 9v power supply and ditch my failing wall wart.
The question I have is - is it possible to get negative voltage from a charge pump?  Is it as simple as flipping the Electrolytics and diodes around?
Any help is greatly appreciated!
Sir H C
Yes it can be done.  If you look at www.maxim-ic.com or other makers of these charge-pumps you can see how to configure them to get negative voltages and which ones can do it.
scotsman
I've got some max1044's - and I've looked over the data sheets and it's like braile to me.  I don't get it.
Could I run negative power through the circuit as is?  Will it still "boost" properly?
I'll be using this layout.
johngreene
Quote from: scotsman on April 06, 2007, 03:49:53 PM
This is the voltage doubler configuration for the max1044 and will only work with positive voltages. The 1044 will create a voltage equal to and opposite in polarity of the input voltage only. The data sheet says you can cascade 2 or more devices to get negative voltages greater than -Vsupply but the output impedance rises dramatically. 5x for 2 devices in cascade.
--john
Sir H C
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1017
Shows at the bottom the inverting configuration of the 1044, with use of 5 pins (named).  So using that and knowing which pins are which you should be able to get one cranking pretty quick.
johngreene
Quote from: Sir H C on April 06, 2007, 04:21:22 PM
Except he is looking for -12V. The inverting configuration you are referring to will only give him -9V.
--john
mattumbi
Make sure to check the current rating for the delay unit & the charge pump...
scotsman
#7
I got it fired up - it puts out around 20 volts and climbs using 1n4001's! when I get it grounded the 1044 starts getting warm.. So something is wrong!   The jumper from pin 2 runs to the negative on the 10µf cap?  A grounding issue?
