Anyone ever added an LED to a ProCo Rat?
Started by anchordown, April 14, 2007, 05:58:23 PM
anchordown
Wanting to know if it's worth trying.
Donald
www.myspace.com/anchordown
www.anchordownband.com
sfx1999
This is a very simple thing to do; you can either use a 3PDT switch or use the Millennium bypass.
To calculate the resistor when using a 3PDT switch, use this equation: R = (Vsrc - Vled)/Iled
Where:
Vsrc = source voltage
Vled = LED voltage
Iled = LED current rating
If you can't find this value, use a resistor with a higher value. In fact, you may want to go even higher if your LED glows too bright.
darron
i did it with a 3pdt. mounted in without any problems. if you look at the pcb though, it looks like there's already some sort of allowance for one? maybe they were just thinking ahead, maybe it's an option? didn't really look into it too hard and the switch was not too healthy so i just did it. the led allowance on the pcb is about where the "A" is on the other side. i don't own a rat, but i'd guess you could do it using the existing dpdt with their special bypass method.
i'd be interested to know...
anchordown
Quote from: darron on April 15, 2007, 08:45:39 AM
i did it with a 3pdt. mounted in without any problems. if you look at the pcb though, it looks like there's already some sort of allowance for one? maybe they were just thinking ahead, maybe it's an option?...but i'd guess you could do it using the existing dpdt with their special bypass method.
i'd be interested to know about this as well...  anyone know about this?
Donald
anchordown
Anyone know what ProCo's special bypass method is?
DZ
Bernardduur
Quote from: anchordown on April 16, 2007, 12:24:31 PM
DZ
Millenium bypass
Am learning something new every day here
SquareLight | MySpace account
darron
DZ
there's a geofex article on it somewhere. can't find it right away in google. basically they use a DPDT switch and wire it as such to eliminate one unnecessary switch, leaving one pole that 'floats'. this is read and transistors act accordingly on that. not a very good explanation, sorry. reallllly tired... brain dead....
