Supa Sustain distortion??
Started by ranchak, May 12, 2007, 11:40:53 PM
ranchak
I just finished the SupaSustain from the GGG site. I used 2n3904 trannys instead of the bc169b, it has a ton of sutain and gain, but it also has a slight distorted sound. I did a search and it seems like this is a common problem with this build. I used a red led from Radio Shack and a photo resistor. I found this at Radio Shack:
http://www.radioshack.com/product/index.jsp?parentPage=family&summary=summary&techSpecs=techSpecs&currentTab=summary&cp=2032058.2032230.2032279&custRatings=custRatings&features=features&accessories=accessories&productId=2049723&support=support&tab=techSpecs
I wasn't sure where my distortion is coming from; either the trannys or the optical end. I think this is worth working through, but I am looking for some guidance.
sfx1999
That is a phototransistor, not a photoresistor. They are polar. They are basically variable current diodes.
ranchak
Thanks sfx1999, any idea about the distortion?
sfx1999
#3
It sounds like a transistor is misbiased.
Did you use the phototransistor you posted, or a CdS cell?
