Poly caps to Rat?
Started by VinSent, April 17, 2007, 07:25:33 AM
VinSent
Can i use poly caps instead of electros in Rat/Rodent? I mean those 1uf,2,2uf and 4,7uf. And does that affect same way as in TS circuit?
Thanks.
oldrocker
If you can find polys with that large a value I would say that would be fine.  I always find it hard to find poly film caps with a value of 1uf and up but I guess it's not impossible.  I use tant 1uF in many of my builds.
VinSent
Thanks. Wima has small polys up to 10uf/50v.
momiel
I think is better you use tantalum caps instead of electrolitics or polyestere. The original rat has no electro inside, the big values is all tantalum. I find WIMA caps sound too hi-fi for distortion fx, if you don't like tantalum try mylar (green polyestere) caps.
I'm sorry but my English sucks!
Freaking with real fuzz boxes...
