FX55C Supra Dist restoration projext
Started by claskow, April 28, 2007, 05:30:25 PM
claskow
Help!
Can't find a 55C schematic anywhere and the FX55B is very different..  Purchased this bugger on ebay a few weeks back - as 'not working' - for $5 plus s/h.  Isolated the problem to a couple of missing caps and bad transisitor.  I replaced the transistor and 'guessed' at the missing caps - have full sound, serious crunch - but very 'bass'y.  I also noticed that there was a cap soldered on the volume pot - connecting lugs 1 and 3.
My questions - Does the cap belong on the volume pot?  What are the original factory values for caps 'C23' and 'C25'?
Any help is appreciated.
analogguru
Transistors a FET´s (Field Effect Transistors) Type: J 201
There shouldn´t be any cap across 1 and 3 on the volume-poti.
C 23: 100p
C 25: 1n
claskow
Thank You!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
claskow
Done and it is perfect!!!  Fuzzy, fizzy - just what it should sound like.  Now, I can get a single-coil, cutting (ie nailfile thru the ears) sound from my LP.  Thanks again!!
