Question On Alpha 107-SF12020-L DPDT Switch
Started by Easywider, April 28, 2007, 03:22:21 PM
Easywider
Switch has an L marked on one side & a 1 , 2 , 3 marked on the other side above the poles , just want to make sure i wire it in right , any advice greatly appreciated !
Easywider
Just bumping this one up , still unsure on the switch poles , can i put this in either way to wire it in , just as long as the poles are horizontal , i'am i o.k. ?.....need advice badly ! !
Easywider
darron
it will take a quick 5 seconds with your DMM to test the switch. If you don't have a DMM then just use an LED, a buzzer, or something similar.
Failing that, you could find a 9 volt battery, clamp one side to a pole and the other to your tongue. From the throw that you expect it to be, clip that to your tongue and you should feel something when you alternate the switch. Maybe this is the least practical method?
Easywider
How would i test the switch with a LED , how would i know which way it goes in by doing this , newbie confused .  :icon_redface:
aron
Easywider
aron , thanks for the info on switches , have a better understanding upon how they work , seems to me that the L should be on the left side as you look at when its in the enclosure, is this correct ? that way the 1(1st set of poles would be on the top) ?
aron
Possibly, but the meter is the only way to be sure. You pretty much have to use a meter in this hobby. Any cheap digital one should do.
Easywider
May sound silly , but how would i go about checking the switch on a multi meter , how would i set the meter & what would i be looking for to make sure the switch would be installed the right way .  :icon_redface: :icon_redface:
darron
Quote from: Easywider on April 30, 2007, 12:47:15 AM
my article explains how a DPDT works with a diagram. link
using the continuity tester on your dmm you will be able to confirm which way everything goes. if you don't have a continuity tester then you can use an ohmmeter set to a really low resistance range,
aron
Set your meter on continuity (it may even beep when a connection is made). Then touch the terminals that you expect to have a connection. If your meter beeps, you guess correct. Now press the switch again and confirm that continuity has been changed and other other set of lugs are connected.
A few minutes will confirm and teach you how a switch works.
Easywider
got a MM today , a Craftsmen , very nice , beeps like crazy at every pole on the DPDT switch i touch , numbers flyin ' , wish i knew how to use it , lol.....now how do i check the switch for the right positioning , want mine the way it is on the GGG layout , can this switch be put in any way like a blue 3PDT , please help ?
QSQCaito
On a dpdt there are 6 terminals.
We could separate them in two rows of 3.
In one position, the middle ones are connected with the lower ones. When stomped, or whatever. the middle terminals are connected to the higher terminals. Grab the manual of your DMM, set it for continuity, or the lowest ressistance possible, and check how the switch works, and who is connected with whom.. It's easier if you write conclusions while you make your tests, so you don't forget.
If it's a DPDT, you can't wire it wrong if you're checking vs a layout.
If it's a 3PDT you actually can, because it has the shape of a square.
Hope it helps
bye bye
DAC
D.A.C
