Different etching method for enclosures?
Started by markm, May 12, 2007, 08:48:23 AM
markm
oldrocker
Meanderthal
 A form of electrolysis? Interesting! Looks like very fine detail is possible... 'course a big mac looks 7" tall in ads too...
MetalGod
That looks like it will save a LOT of time over etching with Ferric Chloride.  I'm gonna sleep on it but I'll more than likely order one, looks to be just the ticket.
:icon_twisted:
MarcoMike
we are working on something similar at my university (I'm a chemist and work at the engineering department...). it is not so easy to get a nice black colour, it depends on the additives in what they call "electrolyte". if you do it with sodium chloride on steel you will get brown instead of black... (not that bad anyway). no idea about aluminum enclosures.
Only those who attempt the absurd will achieve the impossible.
markm
Quote from: MarcoMike on May 12, 2007, 12:32:47 PM
FeCl leaves black in the etching but, the reality is what is left is corrosion.
I usually clean the etched portions out quite well and then spray them with black.
I imagine this new process would be easier but, I wonder how well it would handle artwork as opposed to just lettering.
It does look like it can get quite detailed though huh.
Paul Perry (Frostwave)
That green film..... it looks suspiciously like the usual green chomate screenprinting film.
So if anyone wants to experiment, I bet we could get a DIY system going for a tiny fraction of $xxx.
Screenprinting is advancing all the time, consider http://www.ezscreenprint.com/ where you get the green film (actually a gelatin material with chromate added) combined with the mesh. I bet this is what the etch method uses! and I doubt that you need any very exotic material for the electrolyte, even common salt should do it, jsut get the electrodes the right way around & make the other one copper so it doesn't dissolve. Oh and 5 volts will be plenty.
zjokka
Quote from: Paul Perry (Frostwave) on May 13, 2007, 05:29:46 AM
That would be great. There have been some electrolysis etching experiments before, see the post by Seljer:
http://www.diystompboxes.com/smfforum/index.php?topic=52118.msg410150#msg410150
MarcoMike
QuoteFeCl leaves black in the etching
This electrolytic etching is not really etching.... it is not digging in the metal, the drawing comes out just  as "black metal", not as a "black groove".
I'm gonna try this process on aluminum (with my "thingie") tomorrow, and let you know.
mattpocket
We use this method at work... I am an engineer and the toolmakers use little printed labels to mark tools with the appropriate drawing number... The etch is not normally very deep at all, not like with FeCl, but they only leave it on for a few moments...
Matt
Built: LofoMofo, Dist+, Active AB Box, GGG 4 Channel Mixer, ROG Omega
On the Bench:Random Number Generator, ROG Multi-face, Speak & Spell
My Pop-Punk Band - www.myspace.com/stashpocket
