Questions on Jawari
Started by Seizurema, May 15, 2007, 07:53:34 AM
Seizurema
Hey.
First off I'm new, like very new. So hi.  ;D
Now ok, I am attempting to build a Jawari (off of the circuit snippets site). Looking at the schematic...well I don't see a place for pots (did I mention I was a noob?) can somone help me out here...?  ::)
-Chris
GibsonGM
Hi Chris,
I don't see any pots there, either...must be a stand-alone, simple type of effect, and I would assume the output is at unity with the input, so no volume adjustments required.  You could always put a volume pot after the 100K pulldown resistor on the right side of the schematic, but that will only take volume down...making it louder would require adding a boost stage at the end of the effect.
Occasionally something comes along that is THAT simple  8)
shooter_mi
There's a 10K pot between Q1 and ground, wiper connected to ground via 1uf cap.
choklitlove
and you will want to use that pot, trust me.
my band.                    my DIY page.                    my solo music.
