Is there something like the POG out there?
Started by QSQCaito, May 27, 2007, 01:48:09 PM
QSQCaito
Hi guys. I've searching for long time but haven't found something that could make clean octave up/down. Or 5ths or 3rds whatever.. But I couldn't find anything like the POG/HOG that make clean octave available for DIY. Here in Argentina I can't get those effects and if I can, 400USD to begin with.. too much of my pocket there..
Any help. income.. much appreciated
Thanks to all.
DAC
D.A.C
snufkin
its not clean but
search the e&mm harmoney genarator
http://www.diystompboxes.com/smfforum/index.php?topic=54424.msg416020
also the little known out of production boss hr-2 does some of that kind of ball park and it someimes goes cheap on ebay
easyface,phase 90,many fuzz faces,feedback looper,tremulus lune and so on soon to be ADA!
POG and HOG are digital and are essentially dedicated pitch transposers that ignore all the intervals except for a few strategic ones.
QSQCaito
THanks a lot for the info guys!
Mark, i got you upto the " that ignore all the intervals except for a few strategic ones."
what did you mean with this??
Thanks a lot
bye bye
DAC
D.A.C
Processaurus
Behringer is making a clone of the boss super shifter, that does key specific harmonies, and should be affordable.  Though even the real one sounds nowhere near as good as a second player playing the harmony.
sfx1999
Quote from: QSQCaito on May 27, 2007, 06:23:38 PM
A "true" pitch shifter will permit many intervals that you wouldn't normally consider "harmonies", like a semi-tone up or down, and often even adjustments less than that.  The pitch-shift mode on my Behringer DSP-1000 will permit adjustment in terms of cents.  The POG is a no-nonsense type of harmonizer circuit that gives octaves, with none of the less useful intervals (e.g., a semi-tone or minor third) provided.
