Daisey Chain wire ???
Started by LoudGreg, May 18, 2007, 10:04:35 PM
LoudGreg
Hey there,
I want to make a Multiple Daisey Chain (DC) Wire for my effects but Radio Shack only had Speaker & Hook-up wire.   What kind of Hook-up wire (Or Other wire) would you recomend for this small project ?
Guitar player not a tech............
Meanderthal
#2
 As long as that speaker wire is not painfully crappy you should be fine. Yer just using it for 9v DC, right?  Their hook up wire is solid core, so not good for patch cables of any kind, but fine for permanent wiring inside a box...(some will shout NOOOO, but if it ain't gettin' moved, no big deal).
That zip cord would also work, but might be a bit thick for your plugs.
Look at the wire on wall warts... what works for them will work for daisy chains.
