Tube overdrive(say an English Muff'n)
Started by taylorchuck15, May 30, 2007, 10:42:48 AM
taylorchuck15
Does anybody know how to make a tube overdrive? One that sounds REALLY good?
Built: LPB1, A/B Box
Building: Fooldrive 2, Brian May Booster
QSQCaito
Ok, going serious.. the really good depends among your tastes.. what are more precisely looking for?
D.A.C
DWBH
I also wanna build one. I've seen Real Mctube in Tonepad and Tube driver (chandler) in GGG.
I guess I'll choose Real Mctube.
markm
IMO,
This right here is one of THE Coolest applications of a tube in a Stomper!
From Paul's site;
http://www.diyguitarist.com/
Look for the ShakaTube.  8)
stutter
Look about...find a schematic...copy the preamp..there you go.Whatever you do dont start using starved tube designs..if you want low voltage go with Transistors.I think your best bet would be the Mctube but lower the cathode resistors
MikeH
I've heard you can use other 12 series tubes, say a 12AY7 or 12AU7, in a tube driver to make it less of a distortion, and more of an overdrive (ie less gain).
12AY7 or 12AU7
  12ax7...very common tube,
  12ay7, alot like an ax, *lower gain, pin for pin compatible/direct swap tubes.
  So .. yes.
snoof
the fb-2 alembic tube bass preamp sounds great for gtr.
