re-attaching transistor leg
Started by supergerbil, May 30, 2007, 09:38:59 AM
supergerbil
I was placing a Ge transistor into a socket when the leg snapped off. I tried to solder it back on but the solder covered all the base so all the legs are connected. Is it broken or can I fix it?
~arph
My Guess is that if you placed the tip of a soldering iron directly to the base of a tranny you effectively killed it by doing so.  :-\
markm
Quote from: ~arph on May 30, 2007, 09:43:49 AM
Not neccessarily but, it is a good chance it's dead.
Unless it's truly a precious piece to you, I'd move on.
  Broken < precious, it's alot easier to find another one.
