Practical Construction of Pre-Amps, Tone Controls, Filters and Attenuators.
Started by GREEN FUZ, May 31, 2007, 12:12:07 PM
GREEN FUZ
A bit of a mouthful, yes, but it`s the title of a book I found printed in 1979. A lot of the circuits call for an SN72741P chip. Unfortunately I can find little information on it. Does anyone know of a substitute?
MikeH
The Datasheet archive lists all of these as "Similar Parts"
L741B1
ULN2151M
N5741V
741CE
741CN14
ULN2151D
http://www.datasheetarchive.com/
I think it's another name for an LM741 opamp so you could use some of those, or any modern opamps will probably work.
GREEN FUZ
Thanks guys  :). Don`t know why I couldn`t find that info myself.
  Yup, gotta watch the pinouts of the Single Vs. Dual opamps, easily enough ferreted out what the board or schematic calls for, and a dual can be re-pin-outted to be used as a single, two singles can = dual...but of course the board/wiring will be different.
You'll be able to replace any two of those with a 4558 (any brand) or a TL062/72/82 or an NE5532.  If the circuit uses a 741, then its requirements are not very high, and the circuit can often be improved upon with respect to noise, distortion, current consumption, etc., by use of a different op-amp.  Just make sure you observe correct pinout.  Personally, I find it helpful to scan the schem, and digitally remove and replace the pin numbers.
