Blackfire/Rebote 2.5 sound samples inside
Started by theundeadelvis, July 10, 2007, 03:15:06 PM
theundeadelvis
I just finished my Rabbit Punch (Joe Davisson's Blackfire) and White Rabbit (Rebote 2.5) and thought I'd record a sample of them.
WARNING I am not a good guitarist! Especially at improved recording.
The Mp3 starts with a few strums of my Crate VC50 (4-10 closed back) alone then with the White Rabbit adding a little echo. I go through the longer delays and repeats, lofi extra long delay, longer repeat switch which gets a nice drone going in the background, and then the "ramp" footswitch that allows you to build up to ear bleeding oscillations and then fade them back out.
Then I switch the Rabbit Punch at max gain with a slightly modded Marshall tone stack (which can be removed via footswitch and offers a boost at the same time, which will be adjustable in the next version).
Like I said the playing is bad, and for some reason you can really hear the switching and my picking even though I was a good 10 feet away from the mic with the amp fairly loud, but I hope you can enjoy the circuits!
http://boomp3.com/m/38992b4655e7
If it ain't broke...   ...it will be soon.
