Voltage regulators as AGC?
Started by g3rmanium, July 10, 2007, 03:26:50 AM
g3rmanium
Hello,
had this whacky idea in the morning: Could I use a voltage regulator (say 1.5 V) as an AGC circuit?
Johann
Call me Johann.
Paul Perry (Frostwave)
I doubt you could use one as an AGC device. But as a clipper? Or a distortion device?
I suppose it all depends on how the regulator behaves when it doesn't have enough headroom. ( a 5V reg for example might want 6 or 7V input before it actually gives a regulated 5v out).
plus you have asymmetry to contend with...(or take advantage of!)
Sir H C
How were you thinking of using one as an AGC?  As Paul says, maybe a clamp, or limiter, but AGC is usually more of a VGA with a loop around it to keep the RMS constant.
g3rmanium
Quote from: Sir H C on July 10, 2007, 11:04:40 AM
I don't know if there are RMS voltage regulators, but why not rectifying the signal, amplifying it and then using a voltage regulator to keep it at around 1.5 V or so...
Call me Johann.
soulsonic
So you want to turn your guitar signal into a 1.5v DC supply?
If you want to make a heavily distorted signal that has a constant level - the best choice I can think of is a comparator. If you put your guitar signal into a comparator, the output will be a constant-amplitude square wave at the maximum voltage available to the circuit. So you could run it at 1.5v, or just use a voltage divider to cut it down to 1.5. Either way, it will be constant. I built comparator-based fuzzes before and they can sound really good in a big buzzzy synthy kinda way.
g3rmanium
Quote from: soulsonic on July 11, 2007, 05:47:48 AM
:D No I just want to remove most of the dynamics. I was looking into JFET-based AGC circuits once and they looked simple but maybe something even simpler exists?
Mh that sounds interesting, too. Do you have a circuit diagram?
Call me Johann.
Quote from: g3rmanium on July 11, 2007, 05:36:50 PM
You need to distinguish between clipping (just cutting the tops of the notes at some fixed level) and compression/sustain (detecting the signal level & controlling the gain on an amplifier stage to try to even out the average level.
First approach is simple but gives enormous distortion.
g3rmanium
Quote from: Paul Perry (Frostwave) on July 12, 2007, 12:29:05 AM
I know, I know. I thought that maybe a voltage regulator can do the same as a compressor, just simpler.
Call me Johann.
magikker
I have to say I am really curious about this... I'd love to hear sound clips with one of these doing the clipping.
