LM13600/LM1360/CA3080 Cross Reference
Started by { antonio }, July 17, 2007, 10:55:57 AM
{ antonio }
Hello.
I wanted to know what everyone was using as a cross reference for the LM13600/LM1360/CA3080.  Any help is greatly appreciated.  Thanks. Antonio.
shalom + godspeed.  antonio.
www.myspace.com/magnificat
Cross-reference in what sense?  The LM13600 and LM13700 are both dual OTAs. the CA/LM3080 is a single, and the CA3280 is a dual.  While the 13600/13700 are pin for pin compatible in most respects, and the CA3080 (can or chip) and LM3080 are identical to each other, the two types are not like the 13600/700, and neither are like the 3280 or share its pinout.
Are you looking for an NTE/ECG replacement?
CGDARK
Antonio:
You can still find those parts at Ebay and at a few retailers for example Jameco has the CA3080 ($3.54) and the LM13700  ($1.20) (almost identical to the LM13600) and NTE has the cross reference part equivalent:
LM13600=NTE870
CA3080=NTE902
CG
oskar
NE5517 pin-to-pin compatible with LM13600/13700. Of these only LM13600 is obsolete.
puretube
LM1360 doesn`t fit in there...
(closest nephew is CA3094)
Dan N
