Small Stone Sorrows
Started by hendrix2489, July 23, 2007, 09:19:35 PM
hendrix2489
hey guys, i just wanted to thank you in advance.  I built the small stone from  Fp's Tonepad layout and it is not working.  It bypasses fine but when i engage effect, it is the same, no phasing.  I did the truebypass offboard wiring (http://www.tonepad.com/getFileInfo.asp?id=76)
        and the layout (http://tonepad.com/getFile.asp?id=7 )
No modifications
no part subs except i bought and used the small stone pot from small bear elec..
no conversions
as you can tell there is something seroiusly wrong with my results please help asap
Q1-
C =0
B =0
E =8.1
Q2-
C =0
B =8.8
E =9.2
Q3 to q10
C =9.2
B =0
E =0
Q11-
C =7.4
B =don't know
E =7.6
Q12-
C =7.8
B =7.8
E =7.8
Q13-
C =9
B =  constantly changes very weird
E =7.8
Q14-
C =9.2
B =0
E =0
IC1
1 - 0
2 - 2.2
3 - 2.2
4 - 0
5 - 0
6 - 0
7 - 9
8 - 0
IC2
1 - 0
2 - 2
3 - 2
4 - 0
5 - 0
6 - 0
7 - 9
8 - 0
IC3
1 - 0
2 - 2
3 - 2
4 - 0
5 - 0
6 - 0
7 - 9
8 - 0
IC4
1 - 0
2 - 2
3 - 2
4 - 0
5 - 0
6 - 0
7 - 9
8 - 0
IC5
1 - 0
2 - 7.1
3 - 7.8
4 - 0
5 - 0.5
6 - 9
7 - 9
8 - 0
PerroGrande
I don't mean to offend by this question, but are you sure that you have oriented the transistors correctly and/or are measuring at the correct places?
Second question... are these voltages quiescent? (i.e. pedal powered on, but no input -- preferably input grounded)
I ask because Q1, for example, shows B & C voltages = 0, while the emitter is at 8.1 volts...  This struck me as trouble right away...  I followed the link and pulled up the circuit/layout. I would expect the base of Q1 to be around VBias (~4.8 volts).  The collector of Q1 should not be 0 either...
Many other strange and unexpected voltages...  Q3-Q10 should not all read 9.2, 0, 0...
You show 8.8 volts on the base of Q2, but 0 on the collector of Q1 --- yet on the schematic they are connected by a wire...
I would start by checking component orientation, wiring, traces, etc.
hendrix2489
i will have to recheck the voltages but it seems to be working, but the color switch just seems to brighten the tone a little
hendrix2489
i rechecked my voltages now that i solder/unsoldered and the readings are way better they look realistic and very similar to those on this board,
it sounds amazing i like the color switch too i will post pics when finished with project
