combining ruby amp and LPB
Started by zwound, August 01, 2007, 03:52:27 AM
zwound
Hey all,
My current project is combining a ruby amp with an LPB (switchable), and i've run into a little bit of a question about grounding...should the grounding of the LPB section of the electronics ground in the same place as the ground of the amp section (if that makes sense).
also, if i use a 9v dc jack as the power input...can i just use one power input, which again breaks into 2 positive wires, both of which go into the power inputs of the separate ruby amp and the LPB (if that makes sense). would that work?
I'm an enthusiast...what more can i say.
GibsonGM
If they're using the same power supply, yes, you'd ground it at the input jack. Don't connect the grounds board to board, tho. Each should go to the 1 ground point.
You can run the +9 from the jack, yup.
I've done the same thing, and it sounds pretty good :o)
zwound
#2
Hell yes man.  ;D
it sounds so juicy...but i need to fix one thing and another on my ruby :D
but it brought a tear to my eye...during soloing it was the best SS ive heard so far :D
