Gaussmarkov's Dr. Boogey: scaled down tonestack
Started by Bucksears, August 13, 2007, 12:35:58 PM
Bucksears
I can see the values scaling DOWN by a factor of 10 for the resistors and pots, but it seems that the cap values go UP by a factor of 10.
i.e. 22nF to 220nF, 3nF to 30nF
Also, the treble cap seems to go down by a factor of 100 (680n to 6n8).
Are these values accurate? Shouldn't everything go down proportionally?
- Buck
dschwartz
hmm.. the treble cap was 680pF originally , not nF....6n8 is correct....
to scale down a tone control by X is to divide the Resistors by X and multiply the caps by X..
that way you mantain the corner freq of the filters, but lower the impedance.
remember that the corner freq is f=1/2*Pi*R*C (or something similar)...
Tubes are overrated!!
http://www.simplifieramp.com
Bucksears
Cool - good to know as I am going to apply the same methodology to the VoxEXP II I'm building.
- Buck
