Bypass: using a 3PDT for a DPDT - do I still use a jumper ???
Started by ianvomsaal, August 19, 2007, 06:52:04 PM
ianvomsaal
Quick question - if I'm using a 3PDT switch instead of a DPDT (wired like this):
I understand that I'll just ignore the middle 4-5-6-Lugs of the 3PDT (instead using lugs 7-8-9 instead of lugs 4-5-6).
However, do I still have to jumper lugs 3 and 9 together???
Cheers . . .
- Ian
click here: FOR MY BACKGROUND and TO LISTEN TO SOME OF MY MUSIC
~ Music-washes-away-the-dust-of-everyday-life ~ ART BLAKEY
~ Without-music-life-would-be-a-mistake ~ FRIEDRICH NIETZSCHE
CGDARK
Quote from: ianvomsaal on August 19, 2007, 06:52:04 PM
Cheers . . .
- Ian
If you are using this wiring configuration you don't need to jumper lugs 3 and 9, simply because in the diagram lugs 3 and 6 are not tied together.
CG
