unscrewing boss pedals trouble
Started by loki, August 14, 2007, 12:24:33 PM
loki
has anyone had a hard time trying to unscrew the back lid from boss pedals?
i`ve had a Line selector, a DD3 delay, a SD-1, both old and new, but everytime i can`t seem to take those screws off.. it always ends up with damage on the screwdriver or the screw itself..
has it happened to you too? any suggestion?
thanks   ;)
Papa_lazerous
Ok silly question here but bear with me..........
Are you using the right screwdriver?  screws arent simply cross head there are many different types and if you dont have a good set of screwdrivers you may just end up damaging the screwhead
Hambo
No never from a bought pedal, hammond boxes yes definately! But years of faffing about with weathered motorbike fasteners (often made of some kind of cream cheese) has taught me to select as snug a fit screwdriver as possible, and push as much force as you can, (ie. bodyweight) into it while turning. Get it on a surface and put your entire weight into difficult ones. You can cut a groove with a hacksaw if you knacker the head and get a flat on it.  :-\
the_random_hero
Quote from: loki on August 14, 2007, 12:24:33 PM
thanks   ;)
Nope, I've played around with my DS-1 numerous times and I've never had a problem with the screws.
Completed Projects - Modded DS1, The Stiffy, Toaster Ruby, Octobooster Mk. II, Pedal Power Supply
Processaurus
From the factory some boss pedals are indeed a real bear to unscrew, you need the exact right fitting philips with a nice fat handle to get the leverage, and you have to bear down hard so it doesn't slip and strip the head.
loki
yes indeed... i tried every screwdriver i could get a hold of... both flat and cross..
in the end i only managed to unscrew the top 2 screws... then just bent the lid, there was no other way... :icon_cry:
lvs
#6
A steel screw or bolt can get stuck inside an aluminum hole after a while, and possibly a chemical reaction where the two different metals meet has to do with it - but that's a guess. When I used to work on motorbike engines, I often used this trick : put a phillips screwdriver on the screw head (as if to unscrew it) and give the screwdriver a short blow with a light hammer. That "scares" it, as they would say in Dutch, and then it ain't stuck anymore. But with a stompbox, considering what's inside... I don't know. Maybe as a very last resort...
Hambo
maybe try spraying just a tiny bit of penetrating oil, not so it goes all slopping around inside obviously but a bit might help....
