hearthrob screw up...advice please??
Started by vacuumdust, September 11, 2007, 07:41:36 AM
vacuumdust
I tried to add a blinking LED to my hearthrob last night and I obviously messed it up.   The end result is I now get perfect signal through the effect but no modulation.  I got the LED to light up but it's a steady light which makes sense since there is no modulation.  I thought at first that I fried Q3 but it still doesn't trem with Q3 replaced.  So I'm guessing I fried something else in the LFO section of the effect since it passes signal perfectly but no trem effect.  I guess my question is:  what Q or Q's are related to the LFO section so I can start trouble shooting there...I suppose I could have toasted a cap too but usually you can smell that.  THANKS
markm
Where did you connect the LED?
This is probably the cause of the problem, remove it from the circuit and see if the LFO then LFO's.
vacuumdust
The LED was already out by the time I plugged the pedal back in.  I think I had it backwards now.  I had the anode to C of Q4 and the cathode to ground...I think it's supposed to be the other way around.  So yeah, that's what I did.  I had the longer lead of the LED to C of Q4 through a 3K3 resistor and the short lead to ground...made more sense to me that way but apparently not??  So when I did this I got no light at all.  So I kept the short lead at ground and touched the long lead to the C of Q3 and got the steady light.  So I went back to Q4 again, this time without the resistor(no idea why I did this) to the same result...no light.  Then back to Q3 sans resistor and promply fried the LED. So I just took it out all together and went back to playing where I realized the pedal no longer worked correctly.  So, me dumb.
markm
This is from another post. This is my method, maybe this will work;
Place the cathode end at the collector of Q4 and the anode at ground.
This will give you the blinking LED.
To have the LED double as a status indicator as well, just attach the anode to the switch as normal. When engaged the LED will blink
when disengaged, the LED will be off.
cab42
I did it this way (also from an earlier post):
you can get this effect connecting the cathode of a LED to the collector of Q4 and the anode to battery + with a suitable resistor in between. As far as I can hear it doesn't affect the sound.
I got this idea from the EA tremolo schematic at Runoffgroove.com
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
markm
Quote from: cab42 on September 11, 2007, 09:17:45 AM
Not me, I thought of this myself!  ;D  :icon_rolleyes:
Just kidding, I modeled it right after the ROG EA build!  :icon_wink:
