Question - Analog Delay IC
Started by lynessmy, September 12, 2007, 06:43:53 AM
lynessmy
Can i subs MN3007 with MN3207.
Like vice, SAD1024 with MN3010?
In theory, yes, but the power connections are different and the supply voltages a little different.  NOT a simple pull one out of the socket and stick the other one in substitution.
lynessmy
Thanks Mark. I will google the detail data sheet. This will be my worse case but is still hoping can get the original IC somewhere...
oldschoolanalog
Quote from: lynessmy on September 12, 2007, 09:18:44 PM
... but is still hoping can get the original IC somewhere...
MN3007/3207 and the SAD1024 are available from Small Bear.
You can get the MN3010 from Vintage Planet.
What is the original IC?
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
