the Lovepedal 2 Watt Plexi Combo
Started by Dr Ron, September 12, 2007, 10:36:33 AM
Dr Ron
It's a battery powered effects pedal with what looks like a Celestion speaker.
http://video.google.com/videoplay?docid=5554863023390018771
You can see inside the box at the beginning of the video, and it looks extremely sparse, without a circuit board.
I'm wondering if this is a simple transistor amp.
Does anyone know if there's a similar circuit for DIY?
the_random_hero
I wouldn't be surprised if it was based around the LM386. Check out the Noisy Cricket, Little Gem or Ruby amps - they will all give you the same results.
Completed Projects - Modded DS1, The Stiffy, Toaster Ruby, Octobooster Mk. II, Pedal Power Supply
wampcat1
#2
Dr. Ron, you'd be suprised to know just HOW MANY boutique builders are taking ideas from this board and selling them. That's all I can say about that... Not starting a flame war...
Keep in mind that being able to SELL a pedal does not necessarily mean one has to be original. ;)
Not saying that Sean is doing these things of course... ;)
bw
soulsonic
2 Watts suggests an LM380; so does the two 9v batteries. It could be something else, but that's what jumps into mind first. Mark Hammer has an amp design like that - can't say whether it sounds anything the same though.
The speaker looks like a Weber.
g3rmanium
Quote from: the_random_hero on September 12, 2007, 09:42:49 PM
He has been using the LM386 in the Black Magic before. And since the Black Magic "circuit" was also used in his high gain 1/2 W amp, I guess both 1/2 W amps are also LM386-based.
Call me Johann.
Steben
Maybe it's pushpull (2 in bridge) LM386 on 18V? Would be very acceptable assumption.
Dragonfly
iirc, you can use 2 lm386's and get in the 2w range..but its early here and i'm tired, so memory may be wrong ....
the_random_hero
Quote from: Dragonfly on September 13, 2007, 07:34:53 AM
With full gain, you can get pretty close to 1w/IC, so I wouldn't say it's unreasonable to state 2w output from two in push-pull. And who knows what the wattage output is either? We're relying on his description here  :P
