AB Looper
Started by Blues_Boy_4096, September 25, 2007, 05:47:58 AM
Blues_Boy_4096
OK!
I need an AB looper (dual looper), but using only one footswitch.
I came up with this, in order to minimize the noise by grounding the unused return.
Now, is there any way I can add an LED, with the millennium bypass?
Blues_Boy_4096
Sorry for the bump, but no thoughts on this? ???
mydementia
I'd dump the 'unused return grounding' and put in a dual color LED.
In my AB looper I used one 3PDT to turn the loops on/off and the other to switch from loop A and loop B.  My A/B switch was wired just like yours - aside from the center poles.
It's been my experience with loop selectors that grounding unused inputs is not entirely necessary...
I stomp on this pedal more than anything else in my rig!!
Good luck.
Mike
Blues_Boy_4096
Yeah... at first I thought of doing that, but I've read some posts where people were complaining about noise issues if there was a high gain pedal in the loop.
