77 Grey DOD 250 Build
Started by Baktown, September 18, 2007, 11:43:30 PM
Baktown
All,
I'm getting ready to build a 77 Grey DOD Overdrive 250 from Ulysses Vero layout, and I want to experiment a little with different value components to see if I can tweak it to my liking.  What components should I socket so I can do some experimenting?
Thanks in advance,
Axl Bundy
soulsonic
MartyMart
Socket - IC , Diodes , the .05uf cap to the 47k/gain pot ( .1uf worth trying )
Input cap (0.01uf) I found a 22n (0.022uf) to be nice, cap around the diodes so
you can smooth it down some or leave it "bright" - get yourself a reverse log 500k gain pot
as that will make the range real nice.
Try a pair of 1N4001's or 4002's for diodes - great sound :D
MM>
Cardboard Tube Samurai
If you can get a hold of a metal can style op amp it makes all the world of difference too!
