anyone ever heard of this opamp - TA7027?
Started by caress, September 19, 2007, 12:06:04 PM
caress
i found this metal can 8-pin opamp in an old busted stereo and wanted to see if i could use it for anything...
it's a TA7027(D i think, hard to read)
does anyone have a datasheet or other helpful info?
There is a good chance it is an audio amplifier chip, not an op-amp.
caress
CGDARK
The NTE cross reference say that it is an Integrated Circuit Wide Band Amplifier
Cross reference number NTE726. You can check it here: http://www.nteinc.com/specs/700to799/pdf/nte726.pdf
CG ;D
