signal lugs on a pot
Started by jlullo, October 05, 2007, 10:33:29 PM
jlullo
are the signal lugs on a volume pot the two outside lugs?
ambulancevoice
i guess pin 3 and 2
pin 1 is just were the signal gets dumped to ground
CGDARK
For a volume pot you normally wire the output signal to lug 3, the output jack to lug 2 and ground to lug 1.
CG ;D
jlullo
awesome... thank you so much dudes!  i'm adding a smoothing cap, and wasn't exactly sure
