Dr. Boogey Possible For A Noob?
Started by Schappy, October 10, 2007, 02:50:09 AM
Schappy
I really am looking for high gain pedal and love what I hear from the clips of the Dr. Boogey.
I have built a couple BYOC kits but want to jump into something more challenging.
That being said, I have no experience with Perf, Vero, or PCB etching.
Would this build be too much for a noob?
Auke Haarsma
Quote from: Schappy on October 10, 2007, 02:50:09 AM
nope ;)
but be prepared to work on it for a while. And to debug.
I think you can learn a lot by building this one and getting it to work.
John Lyons
If you feel you can solder cleanly and have a small tip on your iron (1/16" or smaller) you should be fine.
There are a lot of pots to solder but the DB has a good layout to follow at gaussmarkov.net.
Just take your time and make sure you check the caps and measure the resistors as you put them in.
John
Basic Audio Pedals
www.basicaudio.net/
Schappy
My solder tip is a .0093" screwdriver tip. I assume this will be OK. Let me know if there is something better.
John, I know you got back to me regarding the PCB for the Boogey and I appreciate it. Would it be better for me to create the board myself? Would I learn more?
The kits I bought from BYOC I put together in a matter of hours. Im not looking for a quick project as I want to learn as much as I can. The kits were good practice for soldering but it is time for more.
Why would I measure the resistors? Just to confirm the value or do I have to tweek something provided I get different values.
I need all the help I can get but am excited to dig in make some mistakes and learn along the way.
This is a fantastic site and I thank you for your help.
railhead
Yes, to double-check. If you're loading a board with resistors and caps and something's screwy after the build, sometimes it's as simple as having placed a wrong cap, etc. So, depending upon how you work, it's a good idea to verify values.
As for amkinig your own boards, what i usually do is make the circuit as I find it, decide if it's worth pursuing to tweak, etc., then I make my own setup the way I like it (I like in/out, ground, power, etc. along the bottom, and the pots along the top -- as opposed to having them all on one side). I also like to drop my LED resistor onto the board and run traces to and from, which most DIY boards I've seen don't do.
John Lyons
Schappy
The dr boogey board and layout was put together by gaissmarkov and it's very compact. The layout and parts choice was a community effort here a while back and many boards have been made from it with no problems. I would not reccomend making your own layout for this one since it's already tested and found to be good. It's a lot of work and I'm not sure there is much better we can do with it.
By all means do make layouts of other things though. It's a nice skill to have.
As far las learning about the layout, you can read to posts and see what went into making the improved layout.
I have the board if you want it.
John
Basic Audio Pedals
www.basicaudio.net/
