R.G.´s Fake Fender/Brownface/Vibratone Layout here
Started by Morocotopo, October 11, 2007, 06:25:27 PM
slideman82
Quote from: David on October 12, 2007, 12:39:30 PM
Let's see if I can say this right.  "Probably older" would be "probablemente mas viejo"?
Yes, you're right! About Moroco Mole and Secret Squirrel ... that's Cartoon Network business...
Ni bien lo hagas andar, deci que tal suena. Se supone es un tremolo, pero si
hace un poco de phasing se pondria interesante.
Hey! Turk-&-J.D.! And J.D.!
markm
Quote from: slideman82 on October 12, 2007, 03:47:18 PM
Google;
Neither do go well, deci such sounds. It assumes is a tremolo, but if
  It is a bit of phasing pondria interesting.
slideman82
Quote from: markm on October 12, 2007, 03:53:03 PM
Google;
That stands for:
Told us how does it sounds once you finished building it. It is supposed to be a tremolo, but if it makes some phasing, it would become interesting
markm
#23
Quote from: slideman82 on October 12, 2007, 04:01:34 PM
Google;
That stands for:
:icon_lol: :icon_lol:
Wow!
Google works great huh?!
Here's a look at the populated VibraTone PCB;
I liked the opamp version better.
In general, JFETs are simply too variable to rely on.
Morocotopo
#25
Quote from: R.G. on October 12, 2007, 05:04:35 PM
And now you tell us....  ;D ;D
Anyway, here´s a more clear image for etching, and with a scale:
Morocotopo
Morocotopo
John Lyons
RG, so your reasoning is based on the consistency of op amps?
Did you build either...have any sound comments in difference between the two?
John
Basic Audio Pedals
www.basicaudio.net/
B Tremblay
Meaning the one you posted on March 8?  Is there a layout floating around for that version?
B Tremblay
runoffgroove.com
markm
Quote from: B Tremblay on October 13, 2007, 03:42:24 PM
I've been working on that.
markm
#29
Here's a look at both circuits;
It is a bit smaller but not drastically as I had anticipated when I was initially contacted about this.  :icon_neutral:
The 1uF Cap on the lower RH side will indicate what I mean by "component fit problem".
I just don't want to see someone etch a PCB for this and have the project be a disappointment because of this.
alfafalfa
Here is a sample from a real brownface vibrato ( = tremelo)
Does it come close to it ?
http://www.esnips.com/doc/5b4b00f5-48bb-4962-86d7-69737efe7f2f/Real-Brownface-harmonic-vibrato
I heard the sample but would like to hear others before I start building it.
My Tremulous Lune sounds very good too but is of course not a harmonic vibrato.
Alf
QuoteRG, so your reasoning is based on the consistency of op amps?
Yes.
QuoteDid you build either...
I breadboarded both.
Quotehave any sound comments in difference between the two?
The opamp version still uses JFETs for modulation, so there is still some variation. Mainly, there is plenty of gain and you can just trim up the output if you don't like it. That's not always true with JFETs.
I consider the all-JFET version to be a tinkerer's version, or perhaps what a boutique place would turn out to say how it sidestepped ugly opamp sound. It's going to need messed with to get the levels right, JFETs selected, and so on. You can't do that stuff economically on more than a one-at-a-time basis. I consider the opamp version to be the industrial version - what you want if you want it to work first time, every time.
That being said, you could get situations where the residual JFET distortion sounds nice, and might prefer that slight distortion.
B Tremblay
Quote from: R.G. on October 14, 2007, 09:25:47 AM
Not to derail the topic, but I'm curious to find out what happened to be the most recent circuit you've built.
B Tremblay
runoffgroove.com
John Lyons
#33
Thanks for the Observations R.G.
Alfafalfa, that clip sounds really nice, hope the Vibra tone sounds like that!!
John
Basic Audio Pedals
www.basicaudio.net/
I get this feeling that there's about to be a largish number of boutique pedals emulating the old Fender vibrato.   :icon_biggrin:
David
Quote from: R.G. on October 14, 2007, 12:28:39 PM
Not if this thread gets moved to Members Only real quick...
