Newbie Schematic Question
Started by Baktown, October 26, 2007, 06:54:54 PM
Baktown
Greetings all,
Can anyone educate me on what the symbol Vr (in yellow) means on the following schematic?
Also, where would V+ terminate?
Thanks in advance,
Axl
PerroGrande
Vr (or Vref) usually represents the midpoint (reference) voltage required when operating an op-amp from a single supply.
V+ would run to the IC's positive supply pin (and anything else that needs 9v, such as an LED, for example), while its negative supply pin would go to ground.
Baktown
That's sort of what I thought, but I see 2 points where Vr goes, and none for V+.
Axl
GREEN FUZ
#3
Quote from: Baktown on October 26, 2007, 07:04:14 PM
Axl
It`s just above where you`ve indicated the Vr in yellow.
EDIT: Whoops, should have reread the thread before responding. I know that`s not the answer you were looking for.
JOHNO
if the op amp is TLO72,LM833, i would say it goes to pin 8. what opamp is it?
ambulancevoice
#5
Quote from: PerroGrande on October 26, 2007, 06:57:38 PM
yeah, ive been wondering what it means too
appy polly loggies, but im a bit lost
so Vr(ef) means half the supply voltage? if you had a 9v supply, Vr would be 4.5v? Yes?
JOHNO
thats right alex/jack notice the voltage is comin from the two 10k resistors thats the voltage divider
MartyMart
Axl, VR ( Vref ) is the mid point between the + and - voltage, in this case V+= 9v and V-= 0v so VR= 4.5v
On schematics, often not all pins are marked, so it is assumed that you know that for a dual opamp, V+ ( 9v ) is
supplied to pin 8 and V- ( 0v or ground ) is at pin 4
For a single opamp this changes to pin 7 for V+ and stays at pin 4 for V-
Anywhere on the schem where you see a "VR" connection, connect this to your voltage divider, usually the mid point of two
resistors with a cap to ground off the mid point, in this case its the 2 x 10k's
MM.
Baktown
Thanks guys!
The op amp is a 4558, by the way.
Axl
