Atari Punk Console perfboard layout??
Started by brefmint, October 23, 2007, 09:52:56 PM
brefmint
I have never been good at reading schematics. I have all of the parts and pieces to make an Atari Punk Console (556) but I can't seem to find a perfboard layout. I found the Veroboard layout and some PCB layouts. Can anyone help me? Thanks,
Matthew
Builds-- Fuzz Face, Tubescreamer(x2), AMZ Miniboost (x3), AMZ Mosfet Boost, Rangemaster(x2), Atari Punk Console, Ruby Amp w/ Bassman mod, EA Tremolo, Java Boost,
Working on: Tube Reamer/Miniboost Combo
Gila_Crisis
you can do a perfboard layout following a pcb layout! i've done so with my APC  ;) and i built too the one with the 556
Pushtone
Here is a cheat, tape the pcb layout on to the perf
brefmint
I'll give that a shot. Thanks for the tip!
Matthew
brefmint
I wussed out and ordered some Veroboard. I'm gonna try Dragonfly's design. Just not brave enough to take on perf yet I guess.  :-\
ultar
make sure you add a volume control at the output. this thing is LOUD!
and a lot of fun. throw a delay after it for 70's sci-fi sounds.
brefmint
Cool. I can't wait to build this thing. My supplies should come today or tomorrow. What pot should I use for the Volume? How would I wire it in? Thanks,
Matthew
ultar
i think i used a 100k audio pot as my volume control but 50k or 25k should work fine.
using dragonfly's layout do the following:
-connect the purple (output) wire to lug 3 of your volume pot instead of the output jack
-wire lug 2 (middle lug) of the volume pot to the output jack- where the purple wire is going in the vero layout
-wire lug 1 of the volume pot to the same lug on the output jack as the green wire and negative battery wire in the vero layout
i'm pretty sure this is how i did it but can't confirm because a friend is borrowing my atari punk console.
brefmint
Thanks! i just received all my parts to make it. Now I just have to find the time to get started on it!
