exact voltage of boss power supply
Started by benfox, November 22, 2007, 12:48:54 PM
benfox
Hi,
Simple question what is the exact voltage of boss power supply or ibanez ?
9 v or a bit more ?
If you have one of those please give me the voltage exacly i need it to fix a regulation problem.
Thanx
Sorry for my bad english !!
colin trueman
benfox
gez
I should think that it depends on the model/age of the supply.
The one I have was bought in the late 1990s.  It uses a 8V regulator and bumps up the voltage by using a couple of series diodes between the reg's ground connection and actual ground.  End result is around 9.2V output.
