help me mod a Fulldrive?
Started by ruger9, January 29, 2010, 10:47:16 AM
ruger9
Here's my deal:
I have a Fulldrive 2 (toggle version, pre-mosfet), and I'd like to change the CHARACTER/EQ of the boost channel.
Basically, I just want to make the boost channel thicker. Would I be able to just solder a cap (or a cap/res network) directly to the Boost vol pot to achieve this? Or maybe even replacing the pot with a lower-value one?  These ideas come from my working on guitars' vol & tone pots, I don't know if they would translate into a pedal.
Basically, I LOVE my FD2's drive channel. I've been thru dozens of ODs, and always come back to the FD2. However, I never use the boost channel. It seems to add high mids, and I would much prefer it add low-mids, or perhaps at least cut some extra treble, so that adding the Boost channel would be akin to stacking another drive with the FD2, but making it darker & thicker.
Any ideas?
jawaRunner
I have to say this post is very timely since I had the same question.
If I could tag on, I am interested in increasing the gain a tad in the Full Drive 2 Mosfet (Blue Pedal White Knobs).  I have not found a schematic for this pedal.  Does anyone have any thoughts or suggestions and increasing the gain or know any resources that would help?
Thank you.  I appreciate your feedback.
Michael
ruger9
I don't have a schematic for the mosfet, just the regular toggle version. I could send it to you if you want. Actually, it's a schem & a diagram, so depending on what components would have to be changed, it could prove helpful.
ppatchmods
When your life is over, will any of this STUFF really matter?
caspercody
I found a pdf of a project for the Full Drive 2, that has 12 clipping stages. Just pm me with a email address, and I will send it to you.
jawaRunner
Thank you.  I just sent you over a PM.
ruger9
jawaRunner
Hi Caspercody, I popped you over my email.  I am interested in seeing what you have.  Thank you very much!
caspercody
Hi Jawarunner, I sent you an email last Friday. I went and forward it to you today. Let me know if you still do not get it.
jawaRunner
