Should my fuzz face crackle?
Started by moro, December 23, 2007, 11:16:14 AM
moro
I have a silicon fuzz face on a breadboard and it crackles when I turn the volume knob on my guitar. Is this normal? I've tried three different guitars so I'm pretty sure it's not the pots. I'm using the Tantalus schematic:
http://runoffgroove.com/tantalus.html
Instead of the switchable output caps, I'm using a SWTC. Also, I'm using 2N2222 transistors. And I have a 2M2 pulldown resistor at the input.
Here are my voltages:
Q1
E: 0.0
C: 1.4
B: 0.6
Q2
E: 0.7
C: 5.5
B: 1.4
Thanks.
It is very likely that you are getting DC back out of the input to the effect. This could be a solder short on the input cap, a bum input cap, or an input cap put in backwards.
moro
Quote from: R.G. on December 23, 2007, 11:35:09 AM
Ah, you're right! I had the pulldown resistor going to +V instead of ground. :icon_redface: Thank you!
