help: BS170 mosfets with inverse diode
Started by burningman, December 23, 2007, 05:02:41 PM
burningman
I bought a bunch of BS170 mosfets recently and I am trying to determine whether or not they contain an inverse diode. Does anyone know how to check this? I found a datasheet on the web for the BS170 that affirms this but I am not sure whether or not it is different from manufacturer to manufacturer.
amz-fx
Every BS170 mosfet has a reverse body diode due the construction of the device. It is not added as a separate component inside the mosfet.
More info in my blog: http://www.muzique.com/news/
regards, Jack
Let's be clearer - all modern MOSFETs of any stripe whatsoever have an integral body diode as a result of the way the substrate must be isolated from the drain and channel.
burningman
Thanks for the reply guys. The project I am working on is the AMZ Mosfet Booster. Would this mean that I could remove the zener diode as mentioned in the article?
Cheers.
