Need some help matching/calcing germs
Started by Zben3129, December 24, 2007, 06:00:37 PM
Zben3129
Hi guys,
Just got 40 germaniums, 20 RCA's and 20 gt133's. I was just wondering how to calculate leakage and gain. I read the guide over at geo, but I couldn't find a plain equation anywhere.
I was using a 9v battery, a 2.4k resistor, and a 2.2m resistor.
For example, before I pressed the switch, I got .112v, and after I pressed the switch, I got .738v
What would the leakage and true gain be on this particular tranny?
Zach
dxm1
Quote from: Zben3129 on December 24, 2007, 06:00:37 PM
I don't know if there is an 'equation' in that article, but the procedure is clear enough.
According to the article, .112v would indicate 112uA leakage.  .738 - .112 = .626, times 100 would be about
63 hfe.
R.G. has done a great job with GEO, and I trust most anything published there. If I can't fugure it out, I've found
that it is usually my problem, not the info on GEO.
If you have a bunch of transistors to match, and you've built the test jig, read the article again. And maybe again...
PerroGrande
Dave's example is correct if you're using the setup as outlined on GEO.
Of course, the more accurate your resistors, the more accurate the results.
Zben3129
Just wanted some general figures :)
Merry Christmas
Zach
