cmos boost layout question
Started by jdavyd, December 27, 2007, 03:30:07 PM
jdavyd
greetings all,
long-time-reader-first-time-poster here.  i've done some searching and the general consensus about tim e's cmos boost is that it's a decent sounding, easy to build effect. i just happen to have most of the parts laying around so i thought i'd give it a shot on perf based on mark m's layout found here:
http://www.aronnelson.com/gallery/v/MarkMs-Gallery/album15/album76/CMOS_Boost_LAYOUT.gif.html
i'm fairly new, so can someone else confirm exactly where the "In" circuit connects, because if i'm looking at this correctly it seems that the IN is just 2 pads that do not connect to anything. i'm sure i've missed something.
the original schematic can be found about halfway down the page here:
http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
but i don't seem to have enough experience yet to make the 2 mesh in a way that makes sense.
thanks for reading!
tcobretti
Take the '1,2,3' from the layout and move them all one hole to the right.  The #3 lug from the pot should connect to the input wire, #2 should connect to that cap, and #1 goes to ground.
jdavyd
#2
thanks very much! - is it safe to say the others should be moved over one as well? IE level 1 to ground, level 2 is output and level 3 to C4?
