Where can I find 51 uF caps and 20k lin. pots?
Started by 6stringer, January 03, 2008, 11:51:51 AM
6stringer
None of the suppliers I usually use have 51 uF caps or 20k lin. pots.  Anyone have a source for these????
Hopefully a supplier that does not charge $10.00 to ship $2.00 worth of parts.
rikkards
Quote from: 6stringer on January 03, 2008, 11:51:51 AM
Why not try a 47uF which is a bit more common? Not sure about the 20k pots though.
Pedals built: Kay Fuzztone, Fuzz Face, Foxx Tone Machine, May Queen, Buffer/Booster, ROG Thor, BSIAB2, ROG Supreaux,  Electrictab JCM800 Emulator, ROG Eighteen
Present Project: '98 Jeep TJ
ayayay!
Are you sure you don't mean 51 pf?  Does the cap you're looking to replace/install just have a "51" on it?  51 picofarads is very common, but not 51 microfarads.
The people who work for a living are now outnumbered by those who vote for a living.
StephenGiles
6stringer
Of course, 51pf!  I have them on hand,
Thanks!   at least it did not take a 2 x 4 upside the head, this time.
Cheers
miqbal
Tube Screamer heh..!!
In case out of supply someday, just put 50pF and 1pF in parallel, you'll get exactly 51pF.
M. IqbaL
Jakarta
Solidhex
Small Bear sells the 20K "g" pots for Tube Screamer clones...
--Brad
ayayay!
Yeah but while we're at it, what is a good source for the small caps?  Do you guys like the ones from Small Bear?
