CE-2 power supply mods? / is there really any difference in the vibrato mods?
Started by JasonG, January 05, 2008, 02:06:53 PM
JasonG
 Well I am completely overhaling my beloved CE-2. I have done the ring modular mod , "space sounds " mod and next I want to do the vibrato mod and power supply mod. I want to have only a few pedals on my pedal board that can do it all.
I can't find any info on the power supply mod and there seems to be 2 vibrato mods one with electronic switching a jfet and  one without.
Any help would be appreciated.
Class A booster , Dod 250 , Jfet booster, Optical Tremolo, Little Gem 2,  mosfet boost, Super fuzz , ESP stand alone spring reverb red Llama omni-drive , splitter blender ,
NEVER use gorilla glue for guitar repairs! It's Titebond , Elmers, or Superglue
JasonG
Ok I just realized one of the vibrato mods was only for ce-2 clones with true bypass.
Nuts
On the top of the ciruit you have 1S2473 diode, replace it, and the 100 ohm resistor below the diode with a jumper.
On the bottom of the circuit, replace the 10V 220uF capacitor with a 16V  220uF capacitor. watch out the positive and negative side of course !
That's it.
miqbal
I've tried the vibrato mod per Tonepad. It does vibrate, no FET, just one switch, but I don't like it :icon_wink:. It seems only cut the clean signal so the clean signal won't blend into the effect sound, i.e, you will only hear the effect/vibrating sound.
M. IqbaL
Jakarta
