easyvibe sounds too much 'thin'
Started by nooneknows, December 29, 2007, 06:36:26 AM
nooneknows
Hi,
I made the easyvibe with geofex layout, it works, added the pot to accurately blend the signal (in place of the 2 10K resitor on the output), tried to bias correctly, increasing the resistor on the feedback of the first opamp to add a bit of volume, doubled checked every caps.
...still the sounds is a bit too thin, compared to my rotovibe, it always seems like an out of phase pickup  in some part of the sweep excursion, very bright. too much bright.
Is it a normal for the easyvibe?
thank you
PS. I don't want to recreate rotovibe sounds, I'd just want a beefier 'swoosh': and I think in the rotovibe there's something to 'round' up the tone, I see a 4049 inside for example and some diode in antiparallel configuration, both silicon and germanium...
  Very small 'input' [actually slightly to the right of exact input IIRC] capacitor...can let more bass in,
nooneknows
I though about it but I believe the input impedance of the opamp is very high, so the cap might not have such influence.
Anyway I'll try it,
thank you
Fuzz
Ciao Marcello! Piacere di conoscere un altro italiano tra i frequentatori di questo magnifico forum!  :icon_mrgreen:
Adesso per tutti...
Please don't go mad for this, but I have to ask for first: did you isolate your led/ldr combos from light?  :icon_wink:
If so (as I think), let me tell you about a similar experience I had: it happened to me that a bad couple of red leds in the Vr circuit (with regular Vr on DMM test) was making the whole lfo work really weak (a current draw problem I think). Try to check if your "Vr leds" are brilliant and lightening (as they should be); if not, try to change them.
Hope this helps!
Fabio
"...the day I tried to win, I wallowed in the blood and mud with all the other pigs..."
nooneknows
Ciao!
the leds ar isolated. Before I put the leds on the board I checked their functioning on a breadboard, then I used heat shrinking tubes. BTW the ldrs and the leds are the ones suggested in the original article, bought from Smallbear, so everything might be good.
Maybe I could however double cheked them...
thank you, Fabio.
nooneknows
Fabio, BTW, a Soundgarden fan? in that case +1! :)
Fuzz
So...+1 for me!  ;D
I was suggesting to double check the Vr leds...Or maybe you used another method to obtain half the power supply?
george
Change the input cap from .001 uF to .01.
Worked for me ...
george
Just checked my easyvibe - I've actually got an 0.1uF in there - I get as much bass as when the circuit is bypassed.
nooneknows
